Old 09-22-2015, 05:45 AM
Paintwerks Paintwerks is offline
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
It's been a little while since I posted with my build progress, but I have been steady at it.
Seatbelts installed.
Heater plumbed in and body side seal thingy panels fitted.
Washer bag and overflow tank fitted.
Fuel pumps and logs assembled.
Fuel line connected to engine.
Fuel filter fitted.
Fuel pressure regulator fitted. All fuel system lines made and run.
Can't fit the fuel pumps until I fit the driveshaft.
Fuel tank fitted. Fuel tank dress ring fitted.
Brake system and clutch system all successfully bled with my Motive pressure bleeder.
Handbrake calipers fitted.
LSA intercooler filler neck fitted.
LSA intercooler reservoir tank and fluid pump fitted, as well as the TR6060 MG9 transmission cooler.
Horns fitted:
Radiator, fan, shroud and cooling system plumbing fitted.
Sime
www.paintwerks.com.au
