Old 09-24-2015, 01:31 PM
jhv48 jhv48 is offline
Originally Posted by Ace23 View Post
I haven't been in the car in a few weeks and honestly can't recall. shouldn't it be going to the left of center when running or when any of the lights or fans kick on?
Will do. Thanks
No, the needle should be to the right of center when running if your alternator is charging properly. Turn on the fans and it will drop to the left suddenly then return almost to center as your regulator adjusts the alternator output to compensate for the high drain of the fans. If the needle is to the left of center while running, you are running on battery power instead of alternator power and your battery will eventually die along with your engine.
Jim
