Old 09-25-2015, 06:23 PM
133bus 133bus is offline
Cobra Make, Engine: dd cobra,351w mild cam
When I bled the brake on my car I wasted two litters of brake fluid trying to get a firm peddle...bled them over and over with no air appearing at the bleed screw and still very soft brakes...finally I remembered that a lot of the time these parts are from other types of cars so they may not be mounted in the same position...my calipers had been rolled up closer to the top of the rotor which left an air pocket the bleed screw could not get rid of...I took out the top bolt and straightened up the caliper and let it drain...a lot of air came out...problem solved...great brakes...some people take the caliper off and some just jack the car way up in the front...steve
