Old 09-27-2015, 05:25 AM
stephen low's Avatar
stephen low stephen low is offline
Default A good Sunday in the shed
As hoped the panel work is essentially finished in the cabin bar some minor tweaks.
Made and mounted up a transmission lid, that then led me to fitting up the gear lever boot and ring as shown below.
The old gear lever arrangement has grown on me and is likely to stay for now. Tends to fit in with the wider look.......
Then got started on the stereo head unit and tweeters so that I can get them wired up.
Tweeters fitted nicely at either end of the dash and swivel so they can better direct the sound at the listener.
The head unit needed to be offset to miss fittings already located through the tunnel behind the dash. Will allow me to perhaps fit up some form of 12V plug fitting on the left for charging gear.
Can anyone suggest a nice looking 12V outlet fitting for this purpose??
I also repaired and re-painted the hole and I had cut in the abortive attempt to fit a small sub-woofer behind the passenger seat.
And I discovered on Saturday that the owner of the bike shop I use is mates with one of the Blackman brothers, perhaps Garry.
I've sent him a number of photos and an idea of what I am after trimming wise as he said he would forward these to Garry for him to have a look at.
Will see if this changes the trimming direction I've had planned.
So just need to finish wiring for LED's and stereo and all the panels and dash can go back in, then it is just finishing off the heat matting and the car is ready for the trimmer.
Half a chance this might be done by end of week.
Enjoy
slowy
