Thread: Dial Indicators
Old 09-29-2015, 03:19 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Suggest you look at Jeg's part number 620-15980. This is Lakewood part number 15980. Price is $33.99 plus freight. The advantage with using these is, they are centerless ground, the washers fit really tight. These washers when welded will allow you to remove the bellhousing and not have to center it again. After you weld the first washer, check it again with the dial indicator before you tack the second washer.
Bill K
