Old 09-30-2015, 05:55 PM
Brian John 2580 Brian John 2580 is offline
Registered User
Default Fuse Block Issues
I purchased a Backdraft Cobra earlier this year and have had several issues with loose and/or corroded fuses. It appears one issue is should you get caught in the rain water drips down onto the fuse block. In addition the fuse blocks appear to be of less than top quality, The fuse clips have lost tension and then there is heat. Once this happens the fuse clips lose their utensil strength and while they can be bent back, this is less than an acceptable repair.
Has anyone experienced this issue?
Is there a better fuse block to utilize when replacing the existing fuse blocks?
While I understand space in the Cobra is limited this is one awkward location to place fuses and relays and to work in this location for more than a few minutes is a pain.
