Old 10-04-2015, 05:34 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Khobra View Post
Dan and Undy,
Thanks for your input. Yes, idle mixture screws are somewhat sensitive but not like they should be. The throttle plates are nearly closed and yes, both carbs adjusted equally.
I have drilled small holes in the primary throttle plates which did help a huge amount but I don't want to go that direction in this case if I don't have to. I would rather take the air bleed restriction route.
The following may be a wild goose hunt as possibly I'm taking your comment out of context, but if your throttle plates are nearly closed you don't need to drill holes in your primary plates. Usually that was done on engines with a big cam and low vacuum because the primary throttle plate had to be opened excessively to get the engine to idle and they end up above the idle transfer slots in the bores - basically taking the idle mixture adjustment circuit out of commission.
You seem to have the opposite condition for some reason (throttle plate possible closed too far). Also, although I have drilled the throttle plate on one Holley before - it was before I discovered that most if not all 4-bbl Holleys have an adjustment screw on the secondary throttle plates. You have to pretty much remove the carb to access it because it's on the underside of the base plate. It's there for two reasons - first, to slightly crack the throttle blades open so they don't become wedged in the bores and won't open, and two, on engines with big cams and low vacuum the secondary throttle plates can be opened slightly more to pass more air at idle, allowing the primary throttle blades to be closed to where they rest in the middle of the idle transfer slots and the idle mixture screws will again function.
If you have a pretty healthy cam and your primary plates in the carbs are excessively closed you might experiment with increasing your idle speed or pulling the carbs and see if the rear secondary plates need to be closed slightly.
ERA 782 Running
