Old 10-06-2015, 11:59 AM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Originally Posted by REAL 1 View Post
More important than ceiling make sure you have enough thickness for the base and correct cement.
Mohawk makes a stout unit.
For my own peace of mind, I would be saw cutting the slab at the anchoring locations. Around 18-24" square and then digging a footing and installing anchor bolts (J-bolts) in the footing along with some minimum 3,000 psi concrete. You can just use a piece of plywood as a template and drill holes to hold the anchor bolts in the correct position while pouring the mud.
