Thread: Cobra Nats 2015
Old 10-06-2015, 03:49 PM
spookypt spookypt is offline
Originally Posted by SydneyChris View Post
hi Spooky,
That explains why I couldnt track you down on Saturday... 5th rear end..!! How can that possibly happen..??
Have you checked your alignment on the GB and the diff, tail shaft play and balance, considered using synthetic oils and a cooler..? What diff casing / internals are you running..??
Look forward to seeing you at next years event.
Chris
Hi Chris, in simple terms... an M3 LSD isn't designed for 320 wide slicks and largish HP with the shock loads that a 4speed dog box can create. Its all about the meat around the pinion and there just isn't enough with the rear end ratio I need to run. Matt
