Thread: Broken Parts
Old 05-01-2002, 08:33 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
With this kind of repetitive failures, i'd say something has got to be set up wrong...perhaps hardware failures or too much movement in the rear end. I put a lot of strain on my drivetrain, and have had only 1 failure--a twisted axle. I would go back thru the car and make sure that there is no play anywhere, and replace every nut and bolt with AN hardware. Certainly a competent machine shop should be able to produce a billet steel hub carrier with bigger bearings....if your pockets are deep enough! I wonder if the center section is moving too much under load......
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
