Thread: Thanks Jeff.
Old 10-07-2015, 06:26 PM
mikiec's Avatar
mikiec mikiec is offline
Default Thanks Jeff.
Been having some intermittent dying issues with the car. About 2 months ago while heading to Mass the car died on 93. I cranked it a few times no start. I check to see if I had gas at the carb. Squirters had a good spray. Hopped back in and the car started. Drove back home. The next day joined some of the NE members for a jaunt around the lake. Everything was good.
last month it dies again on 93. Sat for 5 minuted, it started up and continued for another trip to Mass.
Last week I was out for a drive and it died 6 miles from the house. waited the 5 minutes. Started up so I went back home. 3 miles later it died again. Got home. Figured either fuel of electrical. Turned on the key and checked the fuel pressure gauge. It was bouncing from 2 to 5 lbs.
Next AM checked and now showing 1 LB. Would not adjust with the regulator. Fuel pump.
Talked to Jeff to verify fuel pump. He suggested rebuilding it. Took it apart found the impeller rusted and cracked. Ordered a new one.
I changed the pump, Holley Blue.. Pressure now adjusts correctly. Set it to 5 lbs. Just for grins, changed the cap, rotor and plugs. They needed it.
Took it out for a quick 15 minute jaunt.
Today I got in 3 hours. No Problem. Reset regulator to 6 lbs.
Seems like sitting over the winter crapped it out. Found out that it is a good idea to use some Marvel before getting it ready for winter hibernation.
