Old 10-13-2015, 01:51 PM
Brooklyn-427 Brooklyn-427 is offline
just a thought.. i read in another thread about a aviaid oil pan that was fitted using bolts rather than studs, the result was the bolts were a tad too long and had not clamped the pan down onto the gasket enough, thus causing a leak because the bolts were a fraction too long. They swapped out to the correct studs and corrected the problem. Worth looking too see if you have bolts or studs.
