Old 10-14-2015, 02:57 PM
Khobra Khobra is offline
OK, you know, "eye burning" in the garage is a sign of too lean a mixture, not too rich. In a lean idle condition you do not get a complete burn and raw gas heads out the exhaust. That's why your eyes burn. Just thought I'd pass that along....
Thanks Patrick,
By advancing the time there is more time to burn the fuel. Hence, a cleaner, sweeter smell. Assuming that the condition was rich, would you not agree?
Much has been written and posted about throttle plates exposing too much transfer port thereby causing a rich idle. The solution has always been to close the throttle plates a bit to limit fuel flow from the transfer ports at idle.
By advancing the timing I was able to close the throttle plates at bit and achieving my desired idle speed of approx 950 RPM in neutral and also giving the fuel more time to burn.
