Old 10-15-2015, 04:58 PM
patrickt patrickt is offline
Originally Posted by Khobra View Post
Hi again Undy,
I'm hoping you're following this thread. I was wondering if you're also running push rod oiling or just through the head into the rocker shafts, etc.
And BTW, I am running a Melling high volume pump.
Like Undy, I, too, am running Ersons with my Edelbrock heads and have limited the oil flow with .060 restrictors. Traditional, through the head, oiling. The Erson instruction sheet specifically called for .060, but that is generally right around what a lot of builders use with a solid lifter cam in an FE. Melling HV pump, Canton road race pan.
