Old 10-17-2015, 07:52 AM
hectorturer's Avatar
hectorturer hectorturer is offline
Cobra Make, Engine: SPF 2607 Roush 427IR 8-stack EFI
Default My SPF doesn't start, need help
Hello friends,
Today I am home alone and I jumped into my car to ride and enjoy the sunny Saturday. I hit the ignition and the car won't start, so I did some test.
My engine is a Roush 427, 8 stack system. So far these are the results:
1. I check the battery, is Ok
2. I spray injector cleaner to the 8 stack and the car started and run for 3 sec. So there is electricity/spark
2. I disconected the fuel pump hose that goes to the injectors and is pumping gas when I turn the key on.
I think the injectors are not spraying gas, do anyone know if there is a fuse or relay for the injectors? Any other suggestion or test that I need to do? Thanks for the help!
You drive Coca-Cola "Original", I drive Pepsi...
