Old 10-17-2015, 08:40 PM
lippy lippy is offline
I know electric pumps are noisy but these are Cobras. I don't even hear mine.
Anyway, forgot to provide more details on my setup. The pump is a Weldon and it's guaranteed for life and rebuildable. More expensive but the internals are all metal and it's among the best pumps you can buy. Since my engine puts out 640HP, I ran AN8 Aeroquip Teflon/braided hose and two large billet filters - one at the tank and one up front. I have a bypass regulator at the pump that recirculates to the tank, and a standard regulator up front under the hood. Insulated everything under the hood. Also installed a separate fused power line run through McMaster-Carr heat/oil/abrasion resistant conduit, and a Ford inertia switch in the trunk. Also added a hidden fuel pump cut off switch under the dash so I can cycle the pump to fill the bowl and shut it off with the key on.
