Thread: Clutch Forks
Old 10-19-2015, 11:55 AM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
The clutch fork I have was for a Lakewood bellhousing and a mechanical TO bearing. The fork is rather flat. I used a longer 5/16ths pushrod from the clutch slave cylinder to get greater engagement, but it just doesn't push the throwout bearing into the pressure plate fingers in far enough. The more I adjust it to do so, the throwout bearing then rests against the clutch fingers. I am thinking that the 16935 which shows a greater bend will allow for more movement with less movement from the slave cylinder.
Phil
