Old 10-19-2015, 05:22 PM
hectorturer's Avatar
hectorturer hectorturer is offline
Cobra Make, Engine: SPF 2607 Roush 427IR 8-stack EFI
Hello guys, thanks for the reply. I think is the ECM. I got this message from Roush
If you can access one of the injector connectors, please make the following check if you have not already done so: with the ignition key in the run position, use a test light and check both pins of the injector connector. One should be a constant 12 volts and the other should show no voltage. The 12 volts is a reference signal from the computer. If both pins do not have power, we probably need to service the ECM.
Just did and no power. So today is not a lucky day for me. :-(
I will have to send the ECM and wait for the bill. Mercy Roush, Thanks
You drive Coca-Cola "Original", I drive Pepsi...
