Old 10-21-2015, 02:40 AM
SydneyChris SydneyChris is offline
Engine repair done... Mr Not So Classic, in spite of pulling a 4 trigger cam sprocket off the crate motor replaced it with a SINGLE trigger unit. Is a pretty difficult one to miss.. but he managed it.
The Rollmaster CS1195 is an early Gen IV double row timing chain and sprocket set with a 4 pulse trigger (two long, two short) to suit a 3 bolt cam. It comes with the spacers for the oil pump to enable a direct bolt on and does not require the additional machining at the front of the engine Not So Classic charged me for at the time, even though the install he performed had exactly the same spacers included.
It now starts easily, runs smoothly and doesn't throw cam sensor codes..
Onward we hope from here..
PS: Hoity.. what ever medications you are on my friend, consider changing.. !! seriously.. I really wouldnt want for you to suffer the pain of the CR legacy of his incompetence.
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
