Thread: Clutch Forks
Old 10-21-2015, 04:49 AM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Dan,
I will try to post some pics tonight.
I had to move the slave cylinder closer to the bellhousing. That gave me a little movement but not quite enoough. I am not using any spacers and the slave cylinder does not seem to gave quite enough movement for full engagement. I will try working with it again tonight. Its engaging, but it does not seem like its pushing the clutch fingers all the way down. In addition, with a return spring, it does not pull the clutch fork far enough away from the throw out bearing. The bearing seems to be resting against the clutch with the clutch pedal out. This is being driven by how far I have to adjust thr pushrod toward the clutch fork to get full or close to full engagement.
Phil
