Did some more tweaking and decided to put it together and fire it up. It had been a while since I ran so after some coaxing with starter fluid I started it up. Everything went into gear so I pulled it out of the garage. The engine was idling a little fast. It went into reverse much more easier even with the high idling. Will try to find a stronger return spring and try to take it out for a short run tomorrow night to run through the gears. I did make sure there was no air in the lines.
Phil
