Thread: Clutch Forks
Old 10-23-2015, 07:32 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
I took it out for a short spin tonight. Seems to go in an out of gear fine. Reverse seems much easier. I think I still need to tweak the adjustment some. I have to put the seats back in and put everything back together.
When I aligned the Bellhousing, the starter was much closer to the flywheel. It seems to be working. Time will tell. Used actual starter bolts and the starter is locked in position.
I think I will tackle the pan gasket this winter as seems to be leaking a little near the rear.
Thanks for all the advice gents. Its invaluable to this less experienced back yard mechanic. (:
Phil
