  #80 (permalink)
Old 10-24-2015, 06:00 AM
guye's Avatar
guye guye is offline
Cobra Make, Engine: AP Pace427 (AP4033) GM L77 6.0L TR6060
Originally Posted by Paintwerks View Post
I needed to find a way to get the rear log clearance plus the tunnel has a small peak which didn't allow the plate to be mounted flat anyways. The spacers solved both issues in one shot. ...
I had the same issue, Wazza and Sime, with the weld ridge plus the arc of the hose clamps under the plate. I needed some clearance, but certainly not like Sime. I just used some decent rubber grommets to reduce vibration and added a little extra rubber (about 3mm) and that did the trick.
Guy
Cobra Progress guye-cobra.blogspot.com
