Old 10-25-2015, 09:35 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Originally Posted by Towmaster View Post
Just wondering if your return from the reg goes back into the surge tank or into the main tank. Even though your surge tank is small it shouldn't run out if the return is directed back into the surge tank. You then overflow the surge tank back into the main tank. What size lift pump is it?
Lift pump is a Carter 650HP.
The return from the Reg did go back to the old "little" surge tank. But the crap fuel tank in the my "round-tube" CR has the fuel outlet on the driver side(too many right hand corners and acceleration at Wakefield). Pls my little surge tank had the outlet about 1/4 way up the Surge pot.
The new one is a much better design and about 1L capacity. The pickup is right at the bottom inside the surge tank.
cheers
gregg
