  #26 (permalink)
Old 10-28-2015, 12:01 PM
ACademic ACademic is offline
One thing I did was put some white electrical tape on dead center on the rear lifting bar and I put a couple little ones on the base of the lift on each side of front wheels. That helps my wife line me up coming in and tells her when I am far enough. Once my wheels are centered on the little white tabs, I'm good.
Or hang two ping pong balls from the ceiling with fishing line, roughly 4-6 feet apart, and align them with the driver's side hood latch when the car is on the ramp (but still hanging above the windscreen). You can then use the two balls and the hood latch like a gun sight and you will be within an inch of center on the ramp every single time and without requiring someone else to help you.
