Old 10-28-2015, 10:09 PM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
Usually the bypass is internal, and then closed of by the disc at the bottom of the thermostat. So if you remove the thermostat it'll overheat, as most of the coolant will flow through the bypass passage. I'm not sure if later engines have these.
JD
