Old 10-30-2015, 01:26 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by Pman1961 View Post
I just crawel out from under Ace23 Cobra. The fuel pump appears to be a universal Carter carotor electric fuel pump with what looks like 5/16" plastic molded barbs. It says Carter 4B12A 430 on the housing. I've done a google search and can not find this particular fuel pump. All similar in appearance Carter carotor pumps do not seem to be performance pumps but more of OEM replacements and definitely not capable of supporting a 580+ hp motor. My first response is to ditch this setup and get a proper pump, filters, etc. I asked Ace23 if the car was born with another less horsepower motor as the reasoning for the selection of fuel pump. That answer will come later as he is uncertain until he looks over his paper work. Anybody on here knows the specs on his current pump?
As an update to Pman's comment on the power plant specswe have not come across any indication that the motor in the car is any different than the Keith Craft build sheet. I would say at this point we are 100% sure of what we are working with when it comes to the power plant. The engine dyno shows power still being made and pulling to 7,000rpm......given the 2" headers and the higher duration cam this explains the power band of the car. Hopefully with a fuel pump change and the new plug wires we experience some new results
