Old 11-01-2015, 10:14 AM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
Udo,
You can't upload the pic because you're too new to the forum. Try to message an administrator.
There are LOTS of slaves that can/will work. It's always easiest to replace it with the same part but the manufacturer of that part may change.
I once had a slave on a Cobra that was from an Isuzu/GM pickup. That part went bad (it was made in USA, btw). I went to get a replacement and it was made in China and visibly 'sloppier'. The casting was a step down from the original and the rubber boot wouldn't stay on.
I suggest you call Mike Forte from Forte's Part Connection and get one of his CNC slave and bracket setups. They're very well made, work great and replacement parts are readily available.
rodneym
