Old 11-02-2015, 06:36 AM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
Originally Posted by jcam View Post
I received the new WT gauge and started to remove the existing gauge only to realize the gauge will not slide out past the turn signal assembly/steering column. Do I have to pull the steering wheel/TSA off to remove/install the gauge?
Thanks in advance.
Jamie
No, you shouldn't need to remove the steering column. I replaced mine a couple of years ago and was able to get it out with a little maneuvering.
Ted
