Thread: Newest Problem
Old 11-07-2015, 01:24 PM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
Chassis number? It is possible that you have a hub that is machined in way that prevents the axle from fully seating in the hub recess. The solution is minor machine work on the radius of the hub. A change by the axle supplier in the radius on the axle caused the issue, the factory was unaware of the concern until the cars got some miles on them and the problem occurred.
Let me know the chassis number and I can send you the factory prints that show what work is required.
When this issue is present no amount of torque on the axle nut will prevent the issue. If you jack up the rear and grab the tire at 12 and 6 can you wiggle it up and down?
Seems like Superformance should have contacted owners of the affected cars when they discovered the issue, and supplied the necessary fix, instead of the owners having a failure and then having to pay to fix it.
Chris
