Thread: 588R big block
Old 11-09-2015, 05:56 PM
1795's Avatar
1795 1795 is offline
There is nothing like the look and rumble of an FE, and they are getting scarce. Very few quality vintage FE blocks still available. A 390 is more affordable than a 427 or 428 and can be built to perform very well, and as other have stated, it is difficult to tell a 390 from a 428 or 427 without a lot of work.
An FE gives you all the low end torque that you will need and reality is, most of the time that you are going to want some power to pass some Sunday driver will occur in the 2,000-3,000 rpm range. On an FE that is where your torque is going to be, HP does not even begin to start hitting significant levels until the 4,000 rpm and up range. There is no hesitation with my FE at lower rpms when I want to pull out and get by someone.
