Old 11-12-2015, 02:54 PM
cycleguy55's Avatar
Originally Posted by Double Venom View Post
Hint. Guessing you don't have use a small 4" air/electric grinder?
Even a 7" grinder with a very low grit wheel?
Very lightly TAPER the end as in a "pencil sharpener" design. Very little but 360 degrees, then use a DOUBLE flaring tool (regardless of the type of line.). Couple practice flares and you will look a pro!
GREEN? I've had some done over 5 yrs. Old and never seen green?
Maybe longer than 5 yrs., maybe road conditions....Salt! ??
I have never seen green either - must be the copper corroding.
Like you, I found the trick was to lightly taper / bevel the end of the tubing, though I used a hand held file to do the trick.
Brian
