Old 11-17-2015, 07:35 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
I did what GAV has suggested.
Moved the pivot point. Note that the travel will be affected.
Hence, if you are moving 5 inches of peddle and you have a 5:1 ratio, you will only move 1 inch.
So - then you might want to look at the cylinder size for volume displacement.
If A = B then what you move at the peddle will move at the slave cylinder.
Just some things to think about.
As always, spelling is optional.
Tru
