  #22 (permalink)
Old 11-19-2015, 11:46 AM
chicagocat chicagocat is offline
Originally Posted by MOTORHEAD View Post
Chicagocat:
I have seen the KO adapters on BDR's installed on the wrong side of the car. Ck this by looking at the threads to verify proper rotation.
Also, the rear axle caps were a very tight press fit on some cars.(stub axle I.D. very rough) Had to drill/cut them out.
Exactly where in Fl are you ? Im in Sarasota and can help if you're fairly close.
Ted
Thanks Ted,
I'm in Punta Gorda, so not very far from you. I'll send you a PM. We should get a beer sometime...
I did have a feeling that I should check the threads...I looked and they seem to be correct. Thanks for the advice on the rear axle caps, seems like I should leave them alone if possible.
Brendan
