  #30 (permalink)
Old 11-20-2015, 05:45 AM
Bob In Ct's Avatar
Bob In Ct Bob In Ct is offline
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Had the same issue years ago. this worked for me.
Make sure by threads that you're going in the correct direction.
Lift the wheel off of the ground.
Heat the spinner with a hair dryer to as hot as you can get it.
Hit an ear with a lead hammer. Turn wheel 120 degrees, repeat, etc.
I did this for quite a while but eventually it turned.
Should you ever get it off, be sure to not over tighten when putting the wheel back on. All you need is very snug. Use an anti-seize.
Bob
