Mine is a toploader. Being its the same cable...I had to grab mine with needle nose visegrips & work it out. It was pretty tight in there. It will scar up the cable housing but, since it's a replacement, it shouldn't be an issue. It pushes back in a lot easier. I worked it in by hand.
Obviously you'll find there is a retainer clip with a bolt that needs to be removed before you pull the cable
ERA FIA 2088
