Old 11-23-2015, 11:20 AM
patrickt patrickt is offline
Originally Posted by *13* View Post
I've had my tunnel apart so many times I've considered cutting it into seperate pieces to make it easier... Good luck with it, Paul!
Funny you should say that. One of the recommendations I made to Bob P. was to have a trap door on the passenger side of the tunnel that would allow for easy access to the front U-Joint by just removing the passenger side seat. Greasing the front U-Joint, when you have the outboard braked rear with the hand brake installed, is a PITA. You might as well have a trap door on the driver's side as well to get to the stuff on that side of the transmission.
