Old 05-04-2002, 06:58 PM
Dave Crace Dave Crace is offline
Cobra Make, Engine: Old car with 6 banger
Default Wiring Harness Connectors
Bob,
It seems that the multi-connector that connects harness B to E is the cause of all my electrical problems. Driving home this evening, whenever I turned on the light switch on the dash, the car would die. Turn off the light, car runs. So I made a mad dash for home (without lights). Anyway made it home in one piece and started to check for loose wires. It seems if I move the white multi-connector around under the dash, I can get the lights to come on and off. When I look inside the connector everything looks ok. Is there another type connector that would make a tight connection when put together? There are numerous protrusions on this connector, but nothing to really "pull" it together.
Thanks,
Dave
