Old 11-30-2015, 01:29 PM
Paul Kane's Avatar
Paul Kane Paul Kane is offline
Originally Posted by stallion112 View Post
Do any of the bolts located on the sides of the timing chain cover under the water pump thread into through holes in the block and directly into water jackets? I'm trying to trace the source of some coolant seepage towards the bottom of the cover. It is a DOVE block from ~71.
The 385 Series timing cover has channels on its backside which circumnavigate the water pump holes in the front of the block. This way, should a leak occur there the water will enter the channel in the timing cover which then directs/dumps the water out outside of the cover rather than allowing it to seep further inward and dump into the crankcase.
http://www.highflowdynamics.com
