Thread: Goodbye Kansas
Old 12-01-2015, 12:08 PM
iismet iismet is offline
Originally Posted by strictlypersonl View Post
I absolutely DON'T RECOMMEND this. It's putting a nasty bending moment into the arm and lower pivot shaft. As the suspension goes through its travel, the arms don't remain perpendicular to the hub carrier. Some compliance is necessary.
If you want "solid" on the outer end, use rod ends or spherical bearings.
Yes - I found that out when I cycled it. We are working on rod ends.
x-chr
