Old 12-03-2015, 06:49 AM
eunosracr eunosracr is offline
Things I changed.
High performance radiator.
Headlamp bulbs.
Headlight trim rings.
Headlight Relay
Headlight Switch
Shifter
Shift Boot
Shift Knob
Steel pull knobs for headlight switch, hazards, wipers
Added radiator guard.
Added fire extinguisher in trunk
Replacing oil pan for better clearance.
Installed starter heat blanket.
Installed LED bulbs in reverse lights. These should be standard.
New license plate bracket.
Rubber gaskets around hood and trunk locks
Added stainless steel brake lines.
Added Carb Spacer.
Added gratuitous Cobra badge on nose and trunk.
Installed colored LED bulbs in all dash gauges.
