Old 12-05-2015, 07:42 AM
Ray1960 Ray1960 is offline
Cobra Make, Engine: Contemporary , 427 side oiler
Hi, a lot of good ideas here, make sure you are capable or you no some one that has Tig machine, once filing the jointed area's if its to low you may have to build it up, so you don't file down the aluminum around the area, I would get a piece of aluminum 2 ft , have some one weld a joint on it, file it down, then use multiple different grits of wet sand paper or scotch pads, to get the finish you desire. You will go thru many doing this process, but you will be able to do this. A little trick I use is a little dove soap in your bucket, it keeps every thing clean and reduces build up on your pads. don't be in a hurry, its going to take some time.Good luck.
