Old 12-05-2015, 08:29 AM
eschaider's Avatar
Originally Posted by Ray1960 View Post
Hi, a lot of good ideas here, make sure you are capable or you no some one that has Tig machine, once filing the jointed area's if its to low you may have to build it up...
While TIG welding I believe (but don't know) would work, the body aluminum is not TIG welded by Kirkham. The body sections are gas welded which is a somewhat specialized skill for aluminum.
This thread is displaying the kind of experimental tinkering with a not well understood process that is difficult to do correctly w/o proper mentoring and guidance the first (and probably second and subsequent) times. What's even more disconcerting is that the experimentation is being done on a $160K car (possibly more expensive).
To the OP who started the thread, why not grab a fist full of $100 bills soak them in gas and set fire to them to see if you can put them out quickly enough to just produce the correct golden patina you would like to have on each one? That's how foolish hand finishing an aluminum Kirkham body is — when you've never done it before and do not have a mentor near at hand to prevent you from screwing up.
I presume you work hard for your money like most of us do. Why would you want to toss potentially significant amounts of it to the wind on a lark? Kirkham charges $15K to finish the body. That is not because they are trying to rob you it is because it is that work intensive! There is a hidden message here that is attached directly to your checking account / charge card.
Pay attention, it is worth more than the $15K that Kirkham charges to finish the car correctly. Once the car gets screwed up badly enough to require welding on the body (arghhh) you have entered a whole new phase of expense. Now Kirkham has to repair the previously printine aluminum body work and then get to the $!5K body finishing labor.
This kind of a decision is not rocket science, it is in fact pretty simple stuff ...
Ed
