Old 12-05-2015, 05:36 PM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Use process of elimination; Put the pass side plugs on drivers side, and vicea versa. If problem switches to drivers side, it's a bad plug. If it stays on pass side it's not plugs.
Replace the dist cap next, some electrical defects cannot be seen.
Replace ign wires on pass side.
Still no joy?
Pull pass side header and look for signs of leakage. A leak will leave a soot trail, or other gasket damage may be obvious.
still have problem, try a new coil.
Belay all the above, you have a backfire, not a miss.
Could be induction or exhaust leak.
Are you sure it's not a miss ?
backfire under load, has to be cross-fireing, dist cap, or ign wire. Wire doesn't have to be bad, might be another lead inducting current into ajacent wire.
427's have this problem on #7&8 cyl. If you think it's #1 cyl, try isolating wire from others.
Thinking out loud here.
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
