Old 12-06-2015, 04:23 AM
indianamoon's Avatar
indianamoon indianamoon is offline
Cobra Make, Engine: B & B 289
Default Lagun
Mike,
That control does not take dxf files, but you can program it at the control for all sorts of stuff. I have MX3's at my place. The only problem that I have had with the Prototrak controls is that e\any time anything goes wrong with it, they want $1000 to replace the control box. I replaced each of mine once, and then started fixing them myself. The most commnf problem is the screen going bad. There is an outlet for a remote monitor and you can set a separate monitor on the top if you want. I have a customer with a half dozen that way. I found a bolt in lcd screen replacement, and both of mine have those now. I will try and remember to dig that info out and send it to you. There is actually some color programmed in the output, but of course the supplied screens are only mono. Good luck with it.
Pat
