Old 12-06-2015, 08:03 AM
120mm's Avatar
120mm 120mm is offline
Cobra Make, Engine: Scratchbuild, 289 FIA Replica
Originally Posted by Ron61 View Post
Welcome Drew,
The FFR cares are goods ones but so are a lot of others. They will most likely let you get into a good Cobra for the least amount, but look at others before you take the plunge. I have a FFR Coupe and had a Roadster built on a CR Frame and I like the Coupe very much. But Superformance and others have some great cars too. Also Superformance would probably let you get into a running and finished Cobra quicker than most others as basically all you have to do is get the running gear, engine, transmission, & etc and put it in.
Thanks! I'm not so concerned with "quicker". I like to scrounge, rebuild and fabricate. So, if I could pay less money, I'd be glad to do more work. I'd even be interested in doing a second car built from scratch, but I think building a kit first makes sense.
Originally Posted by *13* View Post
I'm sure you have quite a bit of research to do in the time before you lay your money down. I'd suggest you look at independent rear suspension cars. The short driveline in these cars almost necessitates it. Well built & maintained Cobras retain their value. FFR has a strong following, as do many other brands. The best thing you can do for yourself is put a spreadsheet together & compare the final cost of of a few different cars. Once everything is optioned out the way you want it, sometimes the differences aren't as big as you thought.
It's funny, but the FFR hard-core followers generally look down on the IRS. Possibly because FFR's version was originally based on the relatively weak T-bird unit.
