Old 12-08-2015, 08:11 PM
snakesaway's Avatar
snakesaway snakesaway is offline
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Originally Posted by deano59 View Post
jag and hq holden are the same but commodore is just a smidge bigger some people use them but they pull the studs out on a angle and can break them look for the pcd on commodore and see if thats the same as your back rims . i presume the back end is jag ?
Thanks Deano that's interesting because I was told by a jag wrecker that the PCD is the same as Ford. Yes the back end is Jag and it measures the same as the front 114.3mm between 2 adjacent studs not 2 studs next too each other. I did adjacent stud as that is how et wheel said to measure in their doc on the website. I have seen some methods that measure between to studs next too each other and then multiply by 1.701 I think.
