Old 12-09-2015, 08:15 PM
HPCOBRA HPCOBRA is offline
Hi DV,
My car is tucked away and I can not get at it for several weeks. I would like to purchase the parts and have them ready. The build was a 1995 vintage with a
a 460 and a Richmond 5 speed. I remember the frame mount was a CR part. It was a long angle bracket with a box section welded to it that bolted to the frame. I had to add put a piece of tubing inside the box section because without it when you tightened the main motor mount bolt the box section would crush. Are the motor mounts you listed adapt to this setup? Thanks so muc
