Old 12-11-2015, 04:16 PM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
ive been trying to make my ls look more old school and keeping the drive by wire and i think ive nutted it out at last . there are two ways that i recon will work firstly using one 4 barrel inlet manifold and using the factory injectors and dbw throttle body. machine up a adapter to bolt to the inlet manifold and turn throttle body 90 degs and bolt too adapter and find/make aircleaner to fit .
you can get rocker covers for the LS that look like the old chev covers and relocate the coils ...
the other way is to use 2 dbw throttle bodies and a twin 4 barrel manifold and join the two by a common shaft and make air cleaner to suit . this way aprt from the inlet manifold everthing else is factory and retains the factory ecu important in my case as i need it to talk to the body control module for the auto trans .
cheers dean
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
