Old 12-13-2015, 04:27 PM
Phill Pollard Phill Pollard is offline
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
Hey Troy - is the red car your current one? I have a hard time keeping up with your stable. The Holley vacuum secondary can lids with the vacuum tube fitting can be purchased to allow linking the seconcaries on both carbs together for a common vacuum signal to ensure simultaneous operation. I got a set from Summit. Not sure it makes a lot of difference but another original looking touch.
It's interesting it has chokes on both carbs - does that work pretty well?
LOL...you picked up on the two items I was going to write Troy about.
I see the front choke has power to it but not the rear choke. I hope it is backed off all the way.
First thing I'd do is get the sec. spring covers with compensating ports and get that fixed. Then either find a choke eliminator kit for the rear carb and/or a manual choke setup for the front.
But that's just me!
And yeah, his is the red one, mine is the white one (in his pics). I see some things on his I want to change/do to mine!
Phill Pollard
